reflections
reflections
#1 randolph cohn
Posted 05 November 2017 - 01:12 PM
reflections
reflection done in softplan (do a search -- a few threads on the subject.
do a SEARCH.
i have this reflectivity set at 100,  usually we set the reflectivity much lower.
play with it.
used to depict wetness like on ground (hard surfaces, asphalt, concrete, brick, wood, etc)
if you can't find the answer,  please ask the forum.
indian motorcycle and 3d man from sketchup.
left click to enlarge
Attached File  indian moto reflections.JPG   62.26KB   2 downloads
  • BRUCE PAGE likes this
#2 Jacques Phelps
Jacques Phelps
  • 14 posts
Posted 09 November 2017 - 09:51 PM
Thanks Randy I am going to save this for reference.
#3 randolph cohn
Posted 15 November 2017 - 11:48 AM
in OPTIONS tab of the > EDIT / texture or color
ASK QUESTIONS (easy and fast to do when you know the answers)
btw,  to get "reflections" to work in 3d (softview)
when in 3d-softview,
click on the OPTIONS Tab at the very top
than click on the MODE OPTIONS in the ribbon under the options tab
than in "face options" tab inside of mode options,  check "reflections"
and anything else that you think requires being checked.
(NOTE: might be a good time to look around to see what other
controls are in here )
top left reflections showing back of cad convertible would be a mirror /
these reflections usually on a mirror are best set at 100.
NOTE:  you'd add a light source coming from the mirror side to lighten up objects facing the mirror.
you can play with settings to give it a foggy look as in a steamy bathroom
which you usually wouldn't do. could also use the FOG for an outside rendering
for effect.  not sure what that would accomplish.
horz reflection on solid horz polygon would be on the ground surfaces.
these reflections are best at a lower reflectivity number.
left click to ENLARGE
Attached File  reflections mirror bottom rear.JPG   95.96KB   0 downloads
settings in OPTIONS TAB
maybe some users can share some other effects and settings
that they find useful in renderings.
LEFT click to ENLARGE
Attached File  mirror settings in OPTIONS.JPG   135.78KB   0 downloads
Also tagged with one or more of these keywords: reflections
