Cabin Roof with Loft
#1 Guest_Glen Pitt_*
Guest_Glen Pitt_*
Posted 17 November 2017 - 12:34 AM
Hey Hey
Been a while since I used softplan.  Tried tutorials, but can't seem to find what I need.  I have a simple 40ft x 28ft rectangular cabin.  2nd floor loft is approximately 1/2 of length.  Trying to create a steep pitch roof over 2nd floor which would be open on first floor (where there is no loft).
1. For 2nd floor layout, do I maintain walls along "open area" or do I just add the walls where the loft shall be? If so, how do the walls along the side (hip side of roof) extend to the bottom of the roof?
Any approach strategies would be appreciate.
Posted 17 November 2017 - 12:28 PM
I'd use walls just along the walls to the loft, but split the walls on the lower floor at the edge of the loft and have the walls adjacent to the open area extend upwards until they are the same overall height as the top of the loft walls, and then use a multiple floor roof over the entire structure.
#3 randolph cohn
Posted 20 November 2017 - 07:11 PM
this might help picture what keith is explaining to you about
breaking/cutting the lower wall (at the right side on this illustration)
and fitting that right wall to roof  NOTE: i just cut part
of the right wall to hopefully help show what happens.
note: keith mentions editing the height of that right wall which
is one way and you can also "fit to roof" that wall that starts
at the lower floor and is cut when it hits the loft.
note: i created 2 floors with same height walls all around
the building.
i left the loft area with 2 floors of walls and one floor of walls
at the first floor where it was a 2 story clear space.
i put ledgers (used ring joist) and a beam (used a solid cube for
simplicity to act as the main beam) separating the space for the loft floor
structure.  (note:  i don't use soft list so i can fake items as needed
to keep it simple.   you don't have that option when working with softlist.
btw,  it's really just as simple using the correct items.
#4 Guest_Glen Pitt_*
Guest_Glen Pitt_*
Posted 22 December 2017 - 09:47 AM
sorry for late reply.  Awesome.
i'll give that a try now.
Thank you
#5 Guest_Glen Pitt_*
Guest_Glen Pitt_*
Posted 22 December 2017 - 10:08 AM
Okay.  Got that to work, but now I need to add a shed type roof (symmetrical) from near the ridge to each side for the loft.   Do I cut that out of the main roof?
#6 randolph cohn
Posted 27 December 2017 - 05:36 PM
glen,
i'll be happy to go over the process with you.
send me an email with your contact info and i'll set us up with a "go-to-meeting" session.
after i show you how easy it is, you can show the forum how it's done.
email me at
rpcdesign@aol.com
tell me what version of softplan you used to draw the plans
put "softplan loft with shed dormers"  in "Subject Area"
also "attach"  your floor plan SPD files plus your SPP file
