Unequal Leg Arch Front Door
11 replies to this topic
#1 Allen McDonnell
  • 225 posts
Posted 05 December 2017 - 03:59 PM
Writers block....can someone help me create this front door?  Thanks...
  • 3,500 posts
Posted 05 December 2017 - 09:21 PM
Check out this tutorial ... http://softplan.com/...ening-tutorial/ ... it's for a garage door, but applying the same principle should get you where you want to be.
Also check out some of the manufacturers doors too, as there are already some arched head doors in the library that may match what you require.
#3 Allen McDonnell
  • 225 posts
Posted 06 December 2017 - 09:25 AM
Im not finding it but thanks for the link.
  • 3,500 posts
Posted 06 December 2017 - 09:46 AM
What can't you find Allen?
#5 Allen McDonnell
  • 225 posts
Posted 06 December 2017 - 10:16 AM
I thought you meant that exact door....
Anyway, i got it....  Copied an elevation opening, exploded it, modified it and then recreated a L and R.
  • 3,500 posts
Posted 06 December 2017 - 10:42 AM
Looks good Allen.
  • Allen McDonnell likes this
#7 Zach Dunham
Zach Dunham
  • 1 posts
Posted 10 March 2018 - 09:10 PM
Hey Allen
How did you get the glass in that door?   I tried and I cant get the glass to show up.
  • 3,500 posts
Posted 11 March 2018 - 10:38 AM
How are you trying to setup that door?
#9 Tom Rogers
  • 905 posts
Posted 11 March 2018 - 02:54 PM
Nice. Looks great.   I was just looking for that door.  I will need to create one.  I was short on time and didnt need it for 3D so I had to explode and do it in 2D
"remember... what we are building today, should be what we want in the future"‚Äč
#10 Keith Almond
  • 3,500 posts
Posted 11 March 2018 - 07:28 PM
DOOR GLAZING: This is a section from the thread referred to in post #2
Openings can be added with DETAIL>OPENING SHAPES>DOOR GLAZING
It is probably best if you want grilles to physically draw them if you have multiple windows that require them. The grille function does work on custom designs, but is a little hit and miss as to whether it works as you think it should.
This is an important step .... If you used the door glazing above, it will show as glass - otherwise any other shape that has glass, will need the glass added separately. If you want to include glass, it must be drawn in a dotted line. Personally I find it best to draw a dotted polygon (normally in a different colour). I position it where it's needed, and then right click inside the polygon, choose POLYGON and explode it. That's not the only way, but it works for me, so that's what I use - If you don't explode the polygon, it wont show as glass.
#11 Allen McDonnell
  • 225 posts
Posted 12 March 2018 - 11:58 AM
Exactly what Keith said.
#12 randolph cohn
Posted 12 March 2018 - 12:02 PM
for the glass,
after you've put in the appropriate lines/arcs,
i OFFSET the most inner line/arc 1/4" inward,
edit the arcs to "dashed" (if still solid)
fillet the corners of those new lines/arcs.
feel free to add or correct my directions.
