Hello All,
I could use some guidance as to the correct order from one step of the plan set to the next. Most of what I draw is on a slab, raised slab, or drive under foundation, but I also work with some clients in other states where I need to draw basements. Those projects cause most of these issues, but I run into some of them on most of my projects. Typically I draw my floor plan. once that is working, I will add my floor system, slab for the garage, and generate my basement.
At this point I usually have issues to correct. Some of my plate heights no longer align, some of my windows are at different header heights, and other items seem to need adjusting.
Should I be setting my wall heights first thing, or after the floor system is added?
What function do the garage wall types serve versus the regular walls?
I'm not sure how sometimes my windows end up at all different header heights. Again, could having the floor system affect how they are inserted?
Any tips or recommendations would be appreciated.
Dave
