did the update and tried "block move"
works to the "LEFT" and NOT the Right.
could someone verify this ?
Posted 14 December 2017 - 04:11 PM
Is a window in the block coming to the end of a wall segment. It will stop the movement of everything in the block if that's the case.
Posted 14 December 2017 - 04:17 PM
If I want to move more than 1 window in a plan (just along the wall they are in), it will often screw up and won't allow me to move them. Not sure if it has been fixed yet. I haven't tried the block move much, but it is working on the few items I've tried. I really don't use it much. More often than not I use control select, then move what I've highlighted.
Posted 15 December 2017 - 03:45 PM
Block move seems to be working fine here.
Martin is correct. Block move will will stop if you have a window sliding with the move and it gets to the end of the available wall. I'm guessing this might be what Randy is running into here.
