Any experience with a wall like this?
8 replies to this topic
#1 Guest_Derrik Bauer_*
Posted 22 January 2018 - 04:21 PM
Just curious if anyone has any opinions/experience with this wall type?  Looking at it for a customer.
#2 Mark Petri
  • 1,506 posts
Posted 22 January 2018 - 06:59 PM
We had talked with a builder trying to use such a wall here in Colorado, but it seems it never took off. My engineer thought it was a bad idea. I don't think it will perform as well as a ICF or other wall where there is a better thermal break.
#3 Martin Livingston
  • 693 posts
Posted 22 January 2018 - 07:29 PM
I agree. Get the insulation on the outside of the wall. If you get cold you wear a sweater, you don't eat one.
  • Tom Rogers and Tracy Guest like this
#4 Paul Tacy
Paul Tacy
  • 42 posts
  • LocationWestern Mass.
Posted 23 January 2018 - 03:37 PM
Just trying to figure out the reasoning for this.  It looks like someone is trying to reinvent the wheel.  Is there supposed to be a structural / thermal or some other benefit?
#5 Guest_Derrik Bauer_*
Posted 23 January 2018 - 04:25 PM
The goal is to take advantage of the natural durability of the concrete on the exterior while gaining the insulation value of the foam.  My customer also likes the idea of having a concrete wall exposed to the interior.  When the pour is complete there is no need for inside framing (similar to ICF's), or add finish to the exterior.  ICF's are a great product, but finishing them on the exterior is another step that can go wrong.
More on the inside finish: You would have the option of leaving the concrete exposed, or to install drywall over surface applied batten strips.  Electrical boxes are added to the forms before the pour.  I spoke with a contractor from another market who has experience with this setup and he said the electrical wasn't a big deal to put in the form.
I plan to do some cost comparisons later to see what the overall price difference would be.
Posted 23 January 2018 - 04:39 PM
I foresee huge cost implications pouring 2 separate walls. What R value do you need to acheive where you are?
#7 Guest_Derrik Bauer_*
Posted 24 January 2018 - 05:27 AM
R-18 continuous is the minimum goal.
This would be poured all at once.
https://www.youtube.com/watch?v=E0A42PTzx7s
http://www.thermomas...ip_overview.pdf
#8 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 15 February 2018 - 04:57 AM
did any of you here about Superior walls they are precast concrete foundation system https://youtu.be/nNq9jdXKpD0
#9 Don Gibbons
Don Gibbons
  • 375 posts
Posted 15 February 2018 - 08:04 AM
I've heard that wall called a 'Sandwich Wall' because the foam is sandwiched between concrete. I've seen it used in commercial and agricultural uses but not very often, maybe once or twice in the past 5 years or so.
Here, we would have to get an engineer's stamp on that.
Depending on the application, ICF may be the better route.
