overlooked nuggets in 2016
22 replies to this topic
#1 randolph cohn
Posted 01 April 2015 - 06:32 PM
list any overlooked nuggets that you've found on v2016.
(or in any prior versions for that matter)
NEW in 2016:
in > options / visible items / roof / roof outline DASHED
this save us from having to trace the roof outline with
DASHED lines on your floor plan for your con docs
(or on any plans where you want a dashed roof line)
#2 Philip Frank
  • 560 posts
Posted 02 April 2015 - 04:37 AM
That's one I requested about 4 months ago (probably others too!). Sure is nice to see SoftPlan respond to our suggestions.
Phil
Posted 02 April 2015 - 06:25 AM
Overlooked by whom? - That feature was listed in the details of the 2016 features.
#4 randolph cohn
Posted 03 April 2015 - 01:26 PM
duplicate
#5 randolph cohn
Posted 03 April 2015 - 01:27 PM
softplan v2016 has some new / symbols / trees-high surface for 3d
(disclaimer - i didn't check v2014 for what trees were already there)
NOTE: left click on the image to "ENLARGE"
new 3d high surface trees with names:
leaf of the chestnut trees showing some of the bark
#6 randolph cohn
Posted 03 April 2015 - 05:10 PM
new stuff /  v2016
3d text
site / slopes with reference (3d symbols slope with the site pitch / terrain)
btw,  where can you draw a Flintstones golf cart in jerracic park ?
#7 randolph cohn
Posted 04 April 2015 - 04:18 PM
thomas roman brought to our attention that we now can "curve tops of wall" (top deflection)
tip:  if you put a positive dimension in it'll curve UP.
if you put a negative number in (add a minus sign in front of dimension) it'll curve down.
and as always, you can also curve the wall in plan view  >  draw / curve wall
nice for garden walls
#8 Sam Allen
Sam Allen
  • 133 posts
  • LocationSan Antonio, Texas
Posted 05 April 2015 - 10:06 AM
I've needed this so many times....I haven't played with this yet but it's moved to the top of my list.......thanks Randy...I didn't see anything mentioned about this feature.
#9 randolph cohn
Posted 05 April 2015 - 11:45 AM
can add a CAP to top of curved wall with curved top.
note: check "fixed" on the cap material.
to get materials on the beam end (profile) to show correct,
try checking "scale" and don't check "orient".
the wood material you use can make a difference
on how it looks when your using a "profile" on the "beam end"
#10 Keith Almond
Posted 05 April 2015 - 04:15 PM
Randy, I have to ask, how do you get images inline with the text. I have to add mine, as they won't paste into the text. With the tutorial I've just done, it would have been nice to follow the images through.
#11 randolph cohn
Posted 05 April 2015 - 05:29 PM
keith
i don't understand when you ask
"how do you get images inline with the text"
the only texture i have with an image is the "jerracic park" text (# 6 above) which is done
in NOTES / "3d text" in site mode.
i'm a little slow today.
#12 Keith Almond
Posted 05 April 2015 - 05:48 PM
Sorry Randy, maybe didn't make myself clear. How do you add images into the body of the post , without adding them as an attached thumbnail. I've tried to paste a clipboard image, but it doesn't work.
I'd like to be able to do:
Text - Image - Text - Image - Text - Image - Text.
So that in a tutorial, I can add images at an appropriate place in the text.
The tutorial I just did, would benefit from not having images together at the end.
#13 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 06 April 2015 - 09:10 AM
After you upload a file
Place your cursor where you want the image
and on the right hand side click add to post (or something like that)
-Chris
#14 Keith Almond
Posted 06 April 2015 - 09:25 AM
Perfect, Thanks Chris. That made the Custom Garage Door Tutorial look a lot better!
#15 Keith Almond
Posted 10 April 2015 - 12:53 PM
Overlooked Nuggets .....
I don't remember reading anything about text etc. but the text display on 2016 is MUCH sharper than 2014.
#16 admin
admin
    Administrator
  • Administrators
  • 88 posts
Posted 10 April 2015 - 12:56 PM
See http://softplan.com/?page_id=1826 for the list of changes made to notes.
#17 Keith Almond
Posted 10 April 2015 - 01:01 PM
Thanks, must have missed that one. The difference is much greater than I would have imagined too.
#18 Thomas Roman
Thomas Roman
  • 341 posts
  • LocationSacramento, CA
Posted 14 April 2015 - 09:14 AM
In ver. 2016 the COPY tool does NOT default to the number of copies to the last number that was entered, but rather defaults to one...
I like that change, a lot, as I often ended up with, say, 7 copies of something when I just wanted one.. which was terrible if the 6 additional copies were off-screen, and I did not catch it until later...
indeed, it was me that asked for this change ... so, are you glad I did so?... or are you pissed at me?
#19 Keith Almond
Posted 14 April 2015 - 09:30 AM
Yes, I think that was a good change too. I'd rather have 1 when I need 7, than 7 when I need 1, much easier to handle the fix.
#20 Brad Graber
Brad Graber
  • 295 posts
Posted 14 April 2015 - 09:46 AM
Tom - I think that's a great change.  I think I may have asked for that as well.   The other thing I want is for the default line types to not change when I use draw select to draw a line.  It feels like everytime I use the line command it's drawing a type of line that I don't want, it also affects the pointers in the same way.
