Beam Pockets
#1 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 13 February 2018 - 08:08 AM
Has anyone noticed that when you put a beam in a wall it displays a beam pocket (perfect) but then SP (once you do a cleanup) shortens it and the beam pocket (basically) disappears (not good)?  This is unfortunate.
So in other words.
1.  Draw the beam, set correct left and right projections.  Perfect.  (see pic on left)
2.  Do a cleanup, and it shortens the beam.  (see pic on right
3.  Edit the beam and then SP changes it to how it was suppose to be. (see pic on left)
Any work-a-rounds?
  • Attached File  sp 1.jpg   28.34KB   0 downloads
#2 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 13 February 2018 - 09:05 AM
Hi Allen.
I'm having difficulty reading the images. Any information on the wall type and beam type used would help to replicate the scenario here. Better yet, if you can send a ticket I will take a look at your drawing.
The default beam pocket depth is equal to the width of the beam and it is measured from the inside of the wall that it connects with.
I suspect that you have a framed wall inside of the concrete wall and you need to account for that wall's full thickness when assigning the end projections to the beam.
#3 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 13 February 2018 - 01:12 PM
Ticket number 29896
just sent.
#4 Martin Livingston
Martin Livingston
  • 693 posts
Posted 13 February 2018 - 01:37 PM
If you specify the end properties turn off the "cleanup"
  • John Jones, Allen McDonnell and Brent Hyndman like this
www.cresco.ca
#5 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 13 February 2018 - 03:21 PM
Good one Martin...im good with that.
  • Brent Hyndman likes this
#6 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 14 February 2018 - 02:26 PM
Thanks Allen.
The issue has been reported on CO-48410. Turning off the clean-up will maintain the designated pocket.
  • John Jones and Allen McDonnell like this
