I'm drawing floor trusses for my floor, set 16" height offset 3" up and all is fine until I draw side entrance that is 2x10's set at same height as truss so the offset is up 9.5 when I do that it changes my truss height to 9.5" fro 16" and all the rim joist. I tried anchor but it keeps changing.
Floor joist offset
Started by
Robert Ferreira
, Mar 07 2018 12:21 PM
Posted 07 March 2018 - 12:58 PM
if you have 2 floor systems that have "DIFFERENT" OFFSETS,
you need to EDIT them and give each level a different "LEVEL" NUMBER.
dbl check and make sure all components of each level have the
same level number.
NOTE: you don't have to UNcheck "cleanup" nor do you have to check "anchor"
doing this from MEMORY so double check what i'm saying.
v10 to future 2016+
