for down and dirty
you also have "bay/bow" windows in openings
pick a "bay" close to size you need.
place it in the wall.
it'll have angled sides,
EDIT the opening and go to DISPLAY tab
check "door swing" and put in 90.
it's square off the corners of the bay
to give it a BOX look.
you can fill in the bottom (which is open)
with a solid cube or 3d polygon.
btw, you could also extend the floor system
to help support the box window.
for a quick roof. go to "symbols" / bay
you'll have an option to pick the size
and also can pick the seat if you need one
in your box bay.
as keith mentions, using walls take a little longer
but more authentic since you can put in operable
openings. have some wall at the bottom,
etc, etc, etc,
for the roof you can go to roof mode and draw a roof
just like you would atop any bearing walls.
probably want to use smaller framing members
for the roof.
click to enlarge
box window.JPG 79.04KB
3 downloads
