Hello,
On the attached roof drawing, I have 2 major roofs. Both bear on the same rear wall, with the same plate height. Neither roof edge is perpendicular to the other roof edges. I have tried changing the break point of the long common wall, but I could not get a break that solved the issue. On the final model, ideally, those two rear roof share the same plane. My questions:
1. Would I be better off drawing it as one roof? (tried, but failed...)
2. Adjusting the roof only moves the entire roof edge. Can you adjust one corner?
3. Any other suggestions?
Thanks for any help or ideas...
Dave
