Opening questions
#1 Paul James
Paul James
  • 251 posts
Posted 19 March 2018 - 09:31 PM
Is there a way to add the new elevation opening indicator on existing openings in the library- created before this feature was added?
Also, is there a way to edit the header height of existing openings in the library? When I first created the openings I had a certain header height, a builder wants a different height, so I'm having to manually adjust them all every time.
Posted 20 March 2018 - 06:22 AM
The windows don't have a set header height - it's set in the drawiing options. To adjust the header height, go into FILE > DRAWING OPTIONS > DRAWING OPTIONS > MATERIAL DIMENSIONS >OPENING OPTIONS ... and under WINDOWS change the window offset to whatever you want.
#3 Paul James
Paul James
  • 251 posts
Posted 21 March 2018 - 02:09 AM
Awesome. Thanks Keith, I didn't realize that. I just had to check all the windows back to default offset.
