Is there a setting to show the apply reverse to all drawings in model when you are reversing a drawing? Some of our users at my office have the choice and some dont.
Posted 11 May 2018 - 11:25 AM
It should automatically show. However, it will only come up if you are reversing a drawing that's in the MODEL STACK, it doesn't reverse elevations or sections etc. Check they are reversing the right drawings.
Posted 14 May 2018 - 07:49 AM
Also make sure that the outline box you create to select what will be reversed is large enough to incorporate everything otherwise it will not give you the option. It can easily happen when you have a site plan in the model but generate the outline from a floor plan.
