How do I get an arched transom that is applied over a door. All I can manage arches the door top but not the transom.
How to arch a transom?
Posted 21 May 2018 - 03:55 PM
Edit the transom in the drawing library, and add a deflection to it - I think - Not in Softplan at the moment, but if not, Then edit the transom to an arched casement.
Posted 21 May 2018 - 07:01 PM
Well. arching the transom first and saving it that way is the way to go. But I couldn't figure out how to add it directly on top of the door so I added it to the wall beside the door and slide it over, but it worked and the client is gonna be happy now. thanks.
Posted 22 May 2018 - 08:22 AM
Actually it's not ... The schedule will show the two window as a separate entities.
As I said above ...
Edit the main window ... Add Transom ... set the height you want. Go to FILE > DRAWING OPTIONS > DRAWING LIBRARY > OPENINGS ... Edit the opening you want ... click on the transom and add a deflection. Refresh the display of that window by unchecking and rechecking product code.
Posted 22 May 2018 - 12:41 PM
No, you're right ... Softplan ASSUMES that transoms are square units over the opening with a 1' default for height. However, the transom is configurable in the drawing library.
As with a lot of Softplan, you put an item in the drawing then EDIT it for location, size and style.
Posted 06 June 2018 - 08:29 AM
What I do is create a separate opening for a french door with transom. I don't use the add transom button on the opening as it does not have all the abilities to customize when I want. Create a separate door with a transom added above and then follow like Keith says to adjust the deflection
