Can brackets be visible on exterior only?
7 replies to this topic
#1 Marcie Franklund
Marcie Franklund
  • 24 posts
Posted 23 May 2018 - 09:22 AM
I added brackets to the upper-level plan so that they would show up on the exterior, but I can't figure out how to hide them on the plan?? The ones in the gable peaks especially since they show up in weird places on the plan.
Attached File  plan view.jpg   81.15KB   0 downloadsAttached File  exterior view.jpg   44.45KB   0 downloads
#2 Steven Kirchoff
Steven Kirchoff
  • 113 posts
Posted 23 May 2018 - 09:24 AM
I would like to know the answer to this same question.
#3 Rick Kingsbury
Rick Kingsbury
  • 170 posts
  • LocationSpearfish, SD
Posted 23 May 2018 - 09:25 AM
I use a layer to hide them on the plan.
  • Allen McDonnell and Brent Hyndman like this
#4 Yvon Gonthier
Posted 23 May 2018 - 09:29 AM
I also, like Rick, use a layer called Hidden items
Posted 23 May 2018 - 09:31 AM
Snap ... Every drawing I do has a layer called "HIDDEN" that's set to NO PRINT, just in case I leave it on.
You could however, just check "HIDDEN" on the edit menu (assuming it's a symbol), although it's still semi-visible, it doesn't print.
  • Yvon Gonthier, Tom Rogers and Brent Hyndman like this
#6 Marcie Franklund
Marcie Franklund
  • 24 posts
Posted 23 May 2018 - 09:50 AM
So embarrassing to admit...but I've never done anything with the layers settings! I just made an attempt to figure it out, but it didn't work. I set up a non-visible layer, set to not print, and then changed under the symbol's definition to default to that layer. Did I miss a step?
#7 Rick Kingsbury
Rick Kingsbury
  • 170 posts
Posted 23 May 2018 - 09:58 AM
Make sure to uncheck the visible box.
Posted 23 May 2018 - 04:23 PM
Although you have the symbol defaulting to that layer, you will still have to set each individual symbol already used to be on that layer. Once they are positioned they take the attributes they had at the time they were drawn.
