Openings in Elevations
#1 Travis Stachler
Travis Stachler
  • 11 posts
Posted 31 May 2018 - 05:52 AM
How do I get the arrows out of the openings in a elevation drawing? Just want the elevation drawing to show the opening nothing else.
#2 Yvon Gonthier
Posted 31 May 2018 - 06:09 AM
You have to go in Ststem Options>Materail Dimensions>Opening Otions and uncheck at the bottom Display Operation on Elevations. But this has to be done before you generate your elevations.
#3 Travis Stachler
Travis Stachler
  • 11 posts
Posted 31 May 2018 - 06:20 AM
I did that and regenerated my elevations and the arrows still appeared. Any other options?
#4 Yvon Gonthier
Posted 31 May 2018 - 06:58 AM
Yes. Should have mentioned that the same has to be done in the Drawing Options for existing projects.
#5 Travis Stachler
Travis Stachler
  • 11 posts
Posted 31 May 2018 - 09:01 AM
The arrows are gone off the drawing but now they are showing up when in the Plan sets. Any ideas?
#6 Richard Rubinski
  • 610 posts
Posted 31 May 2018 - 09:19 AM
Try closing that plan set page and re-opening it. That may help. That also happens with the dimension's.
#7 Philip Frank
  • 560 posts
Posted 31 May 2018 - 10:00 AM
I've also found that you can update a drawing in a Planset by moving it slightly. It's like it forces SoftPlan to reload the drawing.
