Exterior Wall Coverings?
#1 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 19 June 2018 - 12:58 PM
After playing with what I learned in the bathroom Friday Fundamental, I have a question.  Can I use wallcoverings on the EXTERIOR of a building?  I have done some tests and it appears to work fine, even when rendered, but I have had issues in the past with interior walls not rendering correctly if on the exterior of a structure.  The wall and floor coverings might allow some quick and easy tweaks on some of my renderings.  This is just for the model rendering, not con docs or softlist…
Dave
Posted 19 June 2018 - 06:31 PM
Yes, you can use wallcoverings on the EXTERIOR. They are not totally predictable, but close enough.
They work really well on renovation work to show blocked in openings in a slightly different colour to make it obvious there's work to do.
CAUTION: If they are round an opening, the opening WILL cut the wallcovering UNLESS the top is above the opening and the bottom is below it, in which case it WON'T.
#3 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 20 June 2018 - 09:21 AM
Thanks, Keith.  I'll keep that in mind.
