Weid Dimension Lines - SP+ 2016
#1 AJ Spino
AJ Spino
  • 91 posts
Posted 19 April 2015 - 01:31 PM
My dimension lines have shot through my work space.  I brought this to the attention of Tech Support but they had no idea what caused the issue.  Their solution is to block move the dimensions to where they belong.  That works, but each time I go into profile mode I have to move the dimension...oddly enough it's always the dimensions at the top of the drawing.
Has anyone else expeienced this?
Posted 19 April 2015 - 06:24 PM
Not experienced it ...
Is there anything out there, on a non displayed layer or drawing mode (although I would have expected tech support to find it it there was!). Try go into visible items and check show everything.
#3 D M
D M
  • 402 posts
  • Location..
Posted 20 April 2015 - 12:08 PM
Have you looked at the 'Inner String Placement' dimension under 'Dimension Options'? .. is it inadvertently set to some huge dimension? (if you're using auto dimension)
I've had the odd extension line stretch out of whack when I block move a drawing, but Ctrl C clears that up, ..
Posted 20 April 2015 - 12:51 PM
I think if it was an Inner String Placement, then it would have happened on the other three sides too.
#5 D M
D M
  • 402 posts
  • Location..
Posted 20 April 2015 - 03:34 PM
True enough.
#6 AJ Spino
AJ Spino
  • 91 posts
Posted 20 April 2015 - 05:09 PM
Keith,
I checked the visible items and went over the area with a fine toothed comb...didn't find anything.  I did discover it does the same thing when I auto dimension the drawing.
Douglas, I tried Cntrl. C...does't help this issue.
#7 Thomas Parker
Thomas Parker
  • 50 posts
Posted 22 April 2015 - 10:52 AM
Hi AJ
Did you check each level of the drawing (roof, floor, ceiling, etc…) see if something was left out there? I’m sure you tried a ‘block cut’ of the entire area! How about if you started a new project file and auto-dimension the new test walls – if it had the same problem then you would know it’s something in your settings – if it dimensions just fine then you know it’s something in your original drawing that’s the problem.
Hope this might have helped some!!! :mellow:
Tom Parker
TJP Designs and Const. LLC
v10 - v2020
