Conical Roof
#1 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 02 July 2018 - 02:22 PM
 Anyone have advice on sheathing a conical roof with luan (lauan)?  Is there a calculator we could use to help us?  Im building a traffic cone that is 7' diameter at base and tapers up 17'-9" +- to 2' diameter.
Could use strips but then would look segmented. Would prefer flat stock.
Thanks.
#2 Harlon Suttle
Harlon Suttle
  • 383 posts
  • LocationOverland Park, Ks
Posted 02 July 2018 - 03:30 PM
Lots of good stuff online: Fine Homebuilding is a pretty good source...is is one link.....
http://forums.fineho...one-shaped-roof
  • Allen McDonnell likes this
Harlon G. " Buddy " Suttle
casekc49@gmail.com
CELL: 913-339-6242
  • 27 posts
Posted 03 July 2018 - 06:10 AM
Rather than lauan, I would recommend flexible plywood: https://www.columbia...nding-plywood/ Lauan is too rigid.  I'm not sure as to what you mean by needing a calculator?
#4 Thomas Davis
Thomas Davis
  • 301 posts
Posted 03 July 2018 - 04:19 PM
If I were building it, I would break it into 3 vertical sections that stack on top of each other. Each section becomes manageable at approx. 6 ft tall.
I would build each section with 2x's standing on end vertically. You will have to bevel / taper each side of the 2x on a table saw, but once you calculate the angle and bevel each one needs to be cut at, it would be a piece of cake.
Calculator - this may be something like what you are looking for. I just googled "calculator to determine angle and bevel of a cone"
http://www.magafor.com/841/uk.htm
