Why does rotating plans screwup all exterior profiles and roofs (specially false gables). Rotating plans to assemble town units together and still to this day, Softplan manages to distroy all the work done before!!!!!!!!!!
Rotating plans
Started by
, Jul 10 2018 06:34 AM
1 reply to this topic
Posted 10 July 2018 - 12:55 PM
I would suggest using the north arrow to rotate the plan. When you change the direction of north you are given the option of rotating the drawing to match. It should rotate the whole shootin' match. You can also rotate everything manually but make sure all of the layers, options are turned on as well as making sure that you select "Display Everything" under the Options/Visible Items tab.
- Scott Kenyon likes this
