As you can see in my model I am struggling with joining walls and stacking windows/transoms above each other.
The first issue is trying to line up the corner boards. I placed a raked wall above the 9' main floor wall in an effort to prevent the inside corner boards from going staight up to the roof. The problem is, I can't eliminate the gap where the walls meet at right angles. I've reduced the tolerence to 1/2" and still can't get the corner boards to line up. I've also experience that gap in the basement where I have a 2x6 wall abuting to a ICF wall.
The second issue is the stacked windows. What is the best/proper way to stack windows or transom windows above each other?
I'm trying to align the upper window height in profile mode but I can't select the upper window as a reference. Is there a way to do that or should I just use Edit to change their offsets?
I'm not sure what the white space between the top of the window and transom represents, shouldn't there be siding there?
In a 9' wall, what determines the distance between the window and a transom and/or in a 18' wall what determines the the distance between the windows...sorry, non builder here asking questions.
