Is there somewhere in the settings for these values? I tried looking through each area and could not find it. I have to go in and change it each time I do a drawings and would be nice to just set it and forget it.
Gable Frieze and Wall Frieze Default Size
Posted 22 April 2015 - 11:20 AM
Brian,
The frieze is IN SYSTEM OPTIONS>MATERIAL DIMENSIONS>TRIM OPTIONS if you set the frieze that you want it should default to that. If there isn't one with the dimensions that you want you can always make one - either a custom or an adaption of an existing frieze - SYSTEM LIBRARY>PROFILES>FRIEZE
Posted 22 April 2015 - 07:14 PM
Brian,
Oh I see. Thanks
