Locally, and I assume nationwide, since almost every wall section I've ever seen shows it this way, the rafter has a "birds mouth" cut and rests directly on the top plate. This works out to a "heel height" of 5" for 2x6 rafter and 2x4 wall and slope of 10/12.
Yet whenever I draw a roof and examine the statistics it almost always shows the rafter sitting 10-14" above the plate and a very large heel height. The drawing of the elevation looks nice but is not drawn correctly since it shows too much brick.
I understand that it works this way because the programmers wanted the soffit line to be continuous around the project so they chose that line to be the benchmark. But that's not the way framers around here work. They vary the overhang length if needed to match soffit lines and raise the rafter only when absolutely necessary.
Is there any way to set the heel height to be the default bench mark and let the soffit line float or is this something that has to be adjusted on each edge?
