I have been using SP since 1994 and find myself stumped.
I have created a basement wall that is comprised of a 44" foundation with 1/2" air space then a 44" insulated 2x4 stud wall, finished with drywall.
On top of the foundation I have a 53" high insulated 2x6 stud wall with Hardipanel on strapping on 3/8" sheathing and finished in drywall.
I have not added paper or vapor barriers to the wall system.
The 2x4 stud wall is fastened to the 2x6 stud wall using a 2x10 bottom plate on the 2x6 wall.
I have attached clips of the wall edit.
My problem is that in the plan view, the image of the wall does not show the components and I cannot get the extensions or dimensions from the 2x4 wall. (See PDF)
Historically, I would add the lower foundation / 2x4 stud wall and edit the height to 44", then include the 2x6 stud wall with edits for a 44" offset and total height of 53" for an 97" high wall system.
I am prepared to revert to my historical process with 2 walls, but I am curious if there is a way to have this wall display the upper and lower stud walls and work with extensions and dimensioning.
