Timber truss visablity
9 replies to this topic
#1 Steven Kirchoff
Steven Kirchoff
  • 113 posts
Posted 03 October 2018 - 09:24 AM
OK I need some help from my fellow SoftPlan users.
I make a timber truss using beams and it shows up in my 3D but not in my cross section.
What am I missing?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 03 October 2018 - 09:53 AM
Did you make it into a symbol? If you did, there are check boxes in the symbol definition for "extract in section" and "extract in elevation".
#3 Steven Kirchoff
Steven Kirchoff
  • 113 posts
Posted 03 October 2018 - 10:31 AM
I did not make it into a symbol
#4 Mark Petri
  • 1,510 posts
Posted 04 October 2018 - 09:05 AM
Is the beam made of a material that is set to be visible while in section view? If you look at your beam definition, then look at materials while in SV you may find it is unchecked for some reason.
#5 Don Gibbons
Don Gibbons
  • 375 posts
Posted 04 October 2018 - 09:31 AM
If it's there in 3D but not in section it probably means that teh objects you created it out of are visible in 3D and not in section. When you first create teh section, click on Options in the menu across the top and then click on Extraction Options in the ribbon bar. When the menu pops up , click on Extract All and see if the timber truss appears.
#6 Dick Masse
Dick Masse
  • 1 posts
Posted 23 December 2018 - 09:20 AM
Hi Don, I have this problem as well. created a 3d timber truss with 3d polys. they are visible in 3d but not in elevations. tried what you have suggested with no luck.  What am I missing?
#7 Steve and Carla Farnam
  • 655 posts
Posted 23 December 2018 - 11:59 AM
We use beams  to create the Timber Framing members which have been easy to
use given they are editable in 2D as well as 3D. We have not had an issue of the
beams not showing in a cross section.
Could be the cross section line location or the include background box not checked
when generating the cross section .spd
#8 David Bearss
David Bearss
  • 76 posts
  • LocationHood River, Oregon
Posted 22 April 2019 - 12:32 PM
Steve and Carla,
am curious as to what you use for your vertical columns. A vertical beam or a Post?
  • Larry Hartensteiner likes this
#9 Steve and Carla Farnam
  • 655 posts
Posted 22 April 2019 - 04:08 PM
Hello David, We used a post for the vertical columns.
#10 David Bearss
David Bearss
  • 76 posts
Posted 24 April 2019 - 11:53 AM
Okay thanks!
