Camera positions
#1 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 05 October 2018 - 01:44 PM
Is there a way to set up standard camera positions so that after each editing session I can resubmit plan that are taken from the same position as the last set so the customer is seeing the revision from the same position?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 05 October 2018 - 02:33 PM
You can save a View File-that should work.
  • 5,303 posts
Posted 05 October 2018 - 03:06 PM
Once you save the view file, EXIT the view and open another generic model window, or if you move the model in the save file window, it will move the saved file as well, whether you want it to or not.
Once saved a view file can be added to a "Sketch" planset, so creating updated views for the customer is as simple as regenerating the views on the planset - you never have to recreate them, and the views are always from the same point.
Generally I save 8 standard views at approximately 45° increments (and a generic model window), and then refresh/regenerate/reorient them as necessary as the model evolves.
#4 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 05 October 2018 - 03:22 PM
Thanks guys that's exactly what I wanted to hear.
