When I draw something like this col. that has a texture applied to it the texture often rotates 90 deg. and stretches to fit. The col. looks like the one on the left when drawn the using onestep I put it into my system library. Then when I insert it into a drawing it looks like the one on the right. If I explode it then it reverts to the original appearance. What am I not doing that I should be doing?
Texture on symbols
Posted 15 October 2018 - 03:13 PM
What format are you saving it in?
Posted 15 October 2018 - 08:13 PM
Are you saving a 3D model? If so, you have a choice how the model is exported. The best choice (IN MY OPINION) is exporting the 3D model as a DWG file.
Posted 18 October 2018 - 12:24 PM
That is a great symbol/post. Would love to see that as a standard to be part of "Post" in Softplan Brent-hint hint.
#10
Posted 18 October 2018 - 03:10 PM
It's a very simple process to create it as a 3D model out of standard solids. You can even use a standard 6" x 6" post in the middle to be able to adjust it to beams.
