Shed Roof Between Two Gables
#1 Jeffrey Elliott
Jeffrey Elliott
  • 58 posts
  • LocationNew Palestine, IN
Posted 17 October 2018 - 02:51 PM
I haven't done one of these in years.  I need to place a shed roof between two dormers and get the overhangs to match.  the main roof is an  8/12 and I believe the best I can do is a 4/12 on the shed.  Does Anyone have an easy way to accomplish this?
See Attachment.
Thank you for the help.
Jeff
  • Attached File  roof.JPG   47.13KB   3 downloads
Jeff Elliott
New Palestine, IN
jeffelliott@me.com
NPI Consulting LLC
#2 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 17 October 2018 - 06:59 PM
Select Draw > Add Shed Roof and click on the beam between the two gables.
It should add the roof at 1/2 the pitch of the roof which it is intersecting.
  • Brent Hyndman likes this
#3 Steve and Carla Farnam
  • 653 posts
Posted 17 October 2018 - 07:22 PM
Once the shed roof is in place edit the edge and set the top to fascia
height to match the top to fascia of the 8/12 roof. The seat cut and heel heights will
adjust as the top to fascia height is adjusted.
#4 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 18 October 2018 - 07:59 AM
If you're still having trouble getting the roof placed, create a ticket and we can take a look.
#5 Joseph Smith
  • 824 posts
Posted 31 October 2018 - 02:49 PM
i'd add another roof:  1 method would be to add another roof with trace roof command the trace around the new area (my yellow lines), edit the porch beam pitch to be lower while leaving the other 3 planes as 'intersect' with 'auto pitch' selected.
#6 Joseph Smith
  • 824 posts
Posted 31 October 2018 - 02:55 PM
another method would be for you to move the lollypop to the porch beam then change that lollypop to a 'double hip'.
