Is there any way to edit the electrical symbols that SP ships with?
There are a few that I use often that I would like to change.
Or a way to add new ones?
What is an spy file?
Posted 04 November 2018 - 04:06 PM
If you need to add a connection line to it later make sure you add a construction point to the symbol when you create it.
Posted 06 November 2018 - 09:36 AM
With a construction point added, the connection will go to the closest construction point within the locate tolerance. In the case of symbols that contain light sources, it will connect to the center of the light source if it is closest and within the locate tolerance.
Without a construction point, the connection will still find the Electrical symbol but the connection will go to the center of the symbol.
Using Cursor snap (F11), the connection will go to the closest snap point of the shapes within the electrical symbol.
