I created a polyline to delineate existing from new. What I wanted is a 1" thick bold line that was easy to see. What I got was two thin lines 1" apart. Fill only created a solid 1" thick line. Also when I edited the pline I had to edit each piece seperately and "repeat edit" would not work. What's the work around?
Polylines
Started by
Dennis Hilborn
, Nov 29 2018 08:22 AM
8 replies to this topic
#7
Posted 29 November 2018 - 10:20 AM
As mentioned, setting a line thickness instead of line width will solve your problem in one step (example included). In other cases, I've also dealt with lines in the past with modifying the "Style Scale" when you edit
- Steve and Carla Farnam likes this
