How are people dealing with beamed ceilings/coffered ceilings or trey ceilings when it comes to having it represented correctly in Soft List? I have created a boxed beam in the beam section to use as a coffered but it does not terminate at the interior of the wall but instead extends to the outside of the stud. I was thinking of using a bulkhead but it seams that wont show correctly in the material list.
Posted 01 May 2015 - 07:25 AM
V11-V2024
Posted 01 May 2015 - 05:59 PM
jeff,
a molding from the interior mode won't attach
to the side of a beam,
you have to create a custom beam with a wall definition.
than you can easily place moldings on the sides of all
the "wall beams" that form a square/rectangle with auto trace.
note, the rooms walls will act as one of the 4 beams
or
you can place a "wall beam" at perimeter of the room.
NOTE: make sure you offset the wall beams so their
tops are offset to the tops of the other walls.
v10 to future 2016+
Also tagged with one or more of these keywords: softlist
SoftPlan →
General Questions →
Add/Remove Wall Definition MaterialsStarted by Colin Freichels , 23 Feb 2024 softlist, materials, wall and 1 more... |
SoftPlan →
General Questions →
Floor Insulation Not CalculatingStarted by Brent Thoeny , 27 Oct 2023 Insulation, Softlist and 1 more... |
SoftPlan →
General Questions →
Shower TileStarted by gary wood , 24 Feb 2023 Softlist |
SoftPlan →
SoftPlan 2022 →
Softlist users wantedStarted by MICHAEL WARE , 10 Aug 2022 Softlist, help wanted, job |
SoftPlan →
SoftList →
Need Example of a SoftList remodel Estimate - ASAP PLEASEStarted by Grant Krull , 28 Oct 2021 Estimate, SoftList, remodel |
