EXTERIOR WALL THAT HAS SIDING ON BOTH SIDES
#1 JOHN PATTERSON
JOHN PATTERSON
  • 162 posts
  • LocationPowell Ohio
Posted 12 December 2018 - 09:42 AM
In the wall definitions I some times have wing walls that have exterior finishes on both sides, usually siding. How do I get the siding on the interior side of the wall definition to reverse so that the orientation is correct for the siding like it shows on the exterior side of the wall definition?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 12 December 2018 - 09:52 AM
If it looks right in 3d and plan view it doesn't matter how it looks in the wall definition. Does it display properly in 3d?
#3 Martin Livingston
  • 693 posts
Posted 12 December 2018 - 11:04 AM
If you want to correct the direction in a section drawing you are able to reverse it
#4 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 13 December 2018 - 05:22 AM
you can copy the siding surface and past it to the other side where you want it
#5 Joseph Smith
  • 824 posts
Posted 07 January 2019 - 09:04 AM
He has a point.  "while in wall definition"  when creating a wall you are unable to reverse horizontal siding.  Martin is correct, after the section is generated you can reverse the siding.
Great opportunity for Softplan to fix this in wall definition.....sidings should be flipped depending on which side of a stud they are applied.
Good catch John
#6 Guest_Derrik Bauer_*
Posted 16 January 2019 - 06:21 AM
I have created backward siding profiles to combat this.
#7 Joseph Smith
  • 824 posts
Posted 16 January 2019 - 10:42 AM
LOL...Amazing!
