Grade runs through house in 3D
#1 David Heim
David Heim
  • 2 posts
  • LocationTraverse City Michigan
Posted 28 December 2018 - 04:18 PM
Suddenly, in all of my projects, I can see the grade line (grass) inside all my houses in 3D mode. Appears the ground is not cutting for the building. I could possibly understand this happening if it were just a single project, but this has happened across all projects. Thanks
#2 Sam Morgan
  • 851 posts
Posted 28 December 2018 - 07:22 PM
if you are using auto horizon, then this is completely normal.  If you are using a site that you have drawn, you likely don't have a building footprint on your site drawing
#3 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 29 December 2018 - 07:16 AM
Put a floor system in and that will cover it up.
#4 Paul James
Paul James
  • 251 posts
Posted 29 December 2018 - 04:08 PM
Besides needing a floor, you can also adjust the auto horizon height- with a 3d window active, options/settings (I think that's where it is).
#5 David Heim
David Heim
  • 2 posts
Posted 04 January 2019 - 02:42 PM
Thanks everyone for your help with this issue. I'm back on the right path going in the correct direction again. Hope everyone has a prosperous new year!
