Hello,
I have some Building Options set to FADE. However, when I print they are way too light. Any way to adjust the amount of fade that is applied? I export to a PDF and then print from the PDF. I'm printing on a HP DesignJet T120.
Thanks!
Posted 22 January 2019 - 04:19 PM
Hello,
Thanks!
Jeremy Plum
Plum Design & Construction
Posted 23 January 2019 - 07:57 PM
Ron, you should be able to change the line to BLACK and thicken them up in MODE OPTIONS.
Posted 24 January 2019 - 12:20 PM
Using pen weights may be the best option. Then set a layer to that pen weight instead of fade. I have section drawings and overlay drawings set with the typical layers all adjusted for pen weights so the things I commonly want lighter and darker are all set. I save that section as a "master" drawing and then copy and paste the created section into that drawing. Sometimes I have to adjust because something doesn't look right or a new drawing item creates a layer I haven't had before, but mostly it just works. It takes a bit to set up initially, but works well for the limitations we have.
