FADE is too light when printed
8 replies to this topic
#1 Jeremy Plum
Jeremy Plum
  • 189 posts
  • LocationBishop, Ca.
Posted 22 January 2019 - 04:19 PM
Hello,
I have some Building Options set to FADE. However, when I print they are way too light. Any way to adjust the amount of fade that is applied?  I export to a PDF and then print from the PDF. I'm printing on a HP DesignJet T120.
Thanks!
Jeremy Plum
Plum Design & Construction
#2 Jeremy Plum
Jeremy Plum
  • 189 posts
Posted 22 January 2019 - 05:03 PM
solved.
I found a previous post from Keith A. using pens. Set it up and it works great.
However, if there is a way to adjust the fade I would sure like to know.
Jeremy Plum
#3 Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 22 January 2019 - 05:32 PM
An adjustable fade control like Autocad would be great.
  • Keith Almond likes this
#4 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 23 January 2019 - 05:33 AM
I AM HAVING THE SAME PROBLEM WITH INTER ELEVATION THE LINES ARE VERY LIGHT IS THERE A WAY TO DARKING THEM UP
#5 Jeremy Plum
Jeremy Plum
  • 189 posts
Posted 23 January 2019 - 06:31 AM
not exactly sure what you mean by inter. but if it is and entity like a box or board end you need to adjust both the outline and the texture. adjust in the edit box for the entity.
Jeremy Plum
#6 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 23 January 2019 - 07:18 PM
INTERIOR ELEVATION IN VISIBLE LINE MODE I WOULD LIKE TO DARKEN THEM UP
#7 Keith Almond
Posted 23 January 2019 - 07:57 PM
Ron, you should be able to change the line to BLACK and thicken them up in MODE OPTIONS.
#8 Mark Petri
Posted 24 January 2019 - 12:20 PM
Using pen weights may be the best option. Then set a layer to that pen weight instead of fade. I have section drawings and overlay drawings set with the typical layers all adjusted for pen weights so the things I commonly want lighter and darker are all set. I save that section as a "master" drawing and then copy and paste the created section into that drawing. Sometimes I have to adjust because something doesn't look right or a new drawing item creates a layer I haven't had before, but mostly it just works. It takes a bit to set up initially, but works well for the limitations we have.
  • Gary McKeon likes this
#9 Gary McKeon
Gary McKeon
  • 558 posts
  • LocationSilverton Oregon
Posted 24 January 2019 - 05:07 PM
That is a very good idea Mark!
