Mono Truss
#1 Paul James
Paul James
  • 251 posts
Posted 15 February 2019 - 06:32 PM
Can anyone get this type of truss show correctly in Softplan?
#2 Steve and Carla Farnam
  • 655 posts
Posted 15 February 2019 - 08:24 PM
Should show correctly given the heel height, roof pitch are set.
You may have to edit the truss and select the closest truss style.
If in a cross section the truss may have to be hand drawn in if unable
to find truss style.
  I have used this style on a couple houses and the truss showed correctly.
#3 Joseph Smith
  • 824 posts
Posted 18 February 2019 - 09:44 AM
Paul, your webbing doesn't show in SP.  Remember, SoftPlan is truss engineering software....but i agree this mono truss should show something generic like on other truss styles.  Leave them a suggestion.
  • Allen McDonnell and Michael Collazo like this
#4 Paul James
Paul James
  • 251 posts
Posted 26 February 2019 - 11:10 PM
Right, Joe- I don't care about the webbing- I won't show that in sections just for that reason.
I didn't give the right example- this is the type I'm having problems with: a mono scissor truss.
I get the same problem on standard pitched roof scissor trusses as well.
#5 Mark Petri
  • 1,510 posts
Posted 27 February 2019 - 11:25 AM
I get some funky trusses when working with SP roofs. So, I often erase or turn them off so as not to show them. I just had this happen with a scissor truss on a very simple roof with a raised heel...
  • Joseph Smith likes this
Posted 27 February 2019 - 12:01 PM
Paul,
Set the roof and then set the ceiling. Trusses will take the space between the two. I don't believe that the program will ever adjust to create the angled heels ... I've never seen that detail used, and I don't think that an intelligent computer program would never be able to assume that's what you want to do.
#7 Yvon Gonthier
Posted 27 February 2019 - 12:06 PM
It seems like the cathedral causes problems. I tried a raised heel and problems started with teh cathedral.
