jagged siding
cleanup roof siding frieze
#1 Derk Burgers
Derk Burgers
  • 91 posts
  • LocationSioux Center, Iowa
Posted 19 February 2019 - 07:21 AM
I've posted a support ticket on this a couple of times and not gotten feedback.
My siding is jagged in the peak of a gable, which wouldn't bother me so much but my gable frieze doesn't show on one side of the gable and shoots past the peak on the other.
Any ideas? I've tried roof cleanup, unchecking "gable provided by roof" and rechecking it.
Thanks!
Attached File  gable.jpg   81.91KB   2 downloads
#2 Steve and Carla Farnam
  • 680 posts
Posted 19 February 2019 - 07:54 AM
Any holes cut on the roof that are not giving the freeze board a stopping point?
is the lower roof set on intersect/vertical , if so it may have to be pulled back from the face
of the taller gable end. If the lower roof is placed on another layer will the taller gable
end siding and freeze board show correctly?
#3 Derk Burgers
Derk Burgers
  • 91 posts
Posted 19 February 2019 - 07:55 AM
Attached File  heel.jpg   106.68KB   0 downloadsI also need to get my siding to cover a tall truss heel. I built up the heels to get more headroom in a bonus room above the garage.
#4 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Don't let you carpenters drink on the job!
I've had similar things happen and "sometimes" can fix it by playing with the roof.  Sometimes a roof bubble just needs to be re-referenced to the same wall and it'll fix it.
  • 5,311 posts
Posted 19 February 2019 - 08:02 AM
Edit the wall and check the - Adjust wall surface to FIT TO SOFFIT checkbox.
  • Allen McDonnell likes this
#6 Joseph Smith
  • 853 posts
Posted 19 February 2019 - 12:00 PM
I take a different approach on high pitch parallel chord or high heel trusses.  I attach the lollypops of ceiling and roof to phantom walls (hidden walls & not shown on the plan).  Now I set the actual wall to a higher then the soffit height.  My section cuts will be incorrect however i just clean them up when drawing sections.
Also tagged with one or more of these keywords: cleanup, roof, siding, frieze
