It's not lumion, but I did make this today:
Posted 14 March 2020 - 01:37 PM
Michael A Collazo
Planmark Design Studio, LLC
Tampa, Florida
info@planmarkstudio.com
Posted 02 April 2020 - 07:01 AM
I agree about profile for siding. I do my high end renderings in Sketchup and V-Ray and when you extract the siding profiles it makes a HUGE difference in the end product.
Many will say that when you get far enough away from the camera it doesn't matter anymore, but I diasagree. Even from a distance it just looks better
Posted 02 April 2020 - 07:03 AM
Do you set the profile in Softplan?
Profile!! Only way to go!!!
Posted 02 April 2020 - 10:45 AM
You dont get accurate shadows with flat texture that simulates a shadow line. In lumion all i have to do is add a little weathering and that provides distinction. Profiles are wonderful. Board and Batten looks great. Siding. And hopefully one day Shake can be a profile. That would be incredible.
Posted 02 April 2020 - 04:20 PM
I noticed in the rendering Allen uploaded the wood texture on the front porch truss is all oriented horizontal, even on the rafter chord and braces. I agree the realism of a true standing seam roof material would be great. As it would with many other details of the components of a model. It is amazing how much better Lumion can make a model look even with the faults of the model.
I also find my horizontal siding profiles don't clean up very well between different drawings in the stack, and often parts of the vertical profiles are offset between floor levels. Certain parts of the model's exterior finishes lack proper fit and finish without several work-arounds. It makes close up realism hard to achieve in a reasonable amount of time. So, perspective, added accents, and the right angle come into play (or some disclaimer). Often I go back to a more sketchy and artistic rendering approach so as not to get the owner hung up on the color schemes or oddity of details that do not model correctly in SP. If I want something to render and replicate reality I use SketchUp or other methods to have full control and correctly model that component when SP lacks the ability.
Posted 03 April 2020 - 09:04 AM
Allen,
No fault to Lumion. It is more the lack of basic detail in the model from SP. I feel in order to get the realistic look, SP ought to upgrade the way many of the details of their program model. The doors should be dynamic (SketchUp term) in that the sticking should remain the same size and the panels should shrink or enlarge. Trusses, rafters, beams, cabinets, roof overhangs, etc. should all be more "editable" and detailed to allow orientation of textures, details of sticking, etc. to be corrected or correctly oriented out of the box. Not that most of us can't deal with it or get past it, but it is a bit of a disappointment when a customer uses some free or cheap online program that does a better job. So, we know it is possible.
Posted 03 April 2020 - 05:05 PM
Allen,
I couldn't agree more, Mark.
Softplan can do some amazing things, and I still feel it is the best residential design program out there. I just wish the 3D aspect was better implemented. And for sure the renderer needs to be updated!
