Does anyone have a disclaimer or verbiage that they use or add to a material take off to inform the customer items may depend on framing methods, wastage, etc.? Fairly easy to write I know but perhaps someone may have something that I may not think about.
Softlist disclaimer
#1
Posted 16 March 2019 - 03:19 PM
Posted 17 March 2019 - 11:18 AM
Estimate Disclaimer:
An estimate is designed solely to provide the contractor/customer with a rough estimate of the amount of material used in the given project. The material estimate will be based upon calculations or data provided by the contractor/customer and such estimate assumes, among other things, normal and typical building and construction techniques. The actual amount of material used may vary from the material estimate due to a number of factors. Consequently, no representation or warranty has been made that the actual amount of material used will not vary from the estimate.
- Philip Frank, Keith Almond, Raymond Johnson and 2 others like this
Posted 18 March 2019 - 07:33 AM
Thanks Harlon. You have some areas noted that I like and need to incorporate. This is what I had:
Note: Material list is generated by Softplan as a Building Information Management system. The material does not include material for due to wastage, change orders, field conditions, bracing, or based on contractor’s method. All material needs to be verified by contractor/vender before any work is to be done and is not the responsibility of designer to understand all construction methods.
- Tim Belcher likes this
Posted 27 March 2019 - 07:10 PM
