Just noticed one other thing as I'm spending my first full day working in 2020. If I'm in 3D and edit an item, as soon as I finish editing, it takes FOREVER to regenerate the view. I have made sure anti alias is off, reflections are off, etc. Not sure if there is something else that can be changed to speed that up. I'm on a high end laptop with a GTX 1060 video card, so I'm pretty sure its not my hardware
3D Regeneration Speed
Started by
, Mar 30 2019 07:24 PM
1 reply to this topic
Posted 31 March 2019 - 01:11 PM
I think I may have solved this one. The Surface Book 2 that I'm using has both a dedicated GPU and 1060 GTX NVIDIA GPU. You have to go in and change settings in the surface if you want a different GPU used on different programs or to be the default. I had it set up as the default on 2018 but needed to go in and change it for 2020. Seems to have sped things up quite a bit here now so hopeful that the issue is solved and may help someone else working on a surface.
- Tom Rogers likes this
