How do you create new linestyles?
#1
Posted 21 May 2015 - 10:32 AM
Posted 21 May 2015 - 10:58 AM
Have a look at this post Tom.
The LINETYPE.DEF and the SITELINE.DEF files can be edited in a standard text editor.
But .... I will repeat .....
VERY UNOFFICIAL .... NOT SUPPORTED .... EDIT AT YOUR OWN RISK
Posted 21 May 2015 - 01:12 PM
Thanks.
I was able to create lines; however, after restarting program and new drawing the drop down list does not reflect the actual lines drawn.
Anyone else have this issue?
Posted 21 May 2015 - 02:35 PM
Depending on how you wrote the "code" will depend on what shows in the menu. Mine seems to work fine, but that probably doesn't help you.
Posted 21 May 2015 - 03:09 PM
Some (mostly dashed) default linestyles, that I did not change, do not display correctly.
Odd. Very Odd.
#6
Posted 12 August 2015 - 08:31 AM
We need the ability to create line type styles from within program.
I did what is in this post however; now I cannot make electrical arc line with proper style.
#7
Posted 12 August 2015 - 08:38 AM
......... I would recommend that if you do mess with these files that you backup the originals to somewhere safe, and be prepared to restore them if there are any issues. ........
It shouldn't have changed any of the standard lines unless you edited them.
I've been doing this a number of years now, and never had a problem with the existing lines. All I've ever done is add new styles to the bottom of the page.
You can always restore your default linetypes.
Posted 12 August 2015 - 11:08 AM
I did mix my new within old code.
Fixed that. Thanks.
Wish List
- create line type styles from within program
- lines depicted in dialog box had same scale as actual line drawing or edited (see picture)
#9
Posted 12 August 2015 - 11:19 AM
This is from a drawing edited before fixing line type file.
Apparently there will be an issue of combining line type files in existing drawings.
#10
Posted 12 August 2015 - 11:28 AM
Yes, if you mix them there may be issues, as some items may use a certain line number ...
You can also try some of these:
The text will look something like this ...
AGAIN ... I TAKE NO RESPONSIBILITY FOR PEOPLE BREAKING THEIR SYSTEMS - THIS IS A NOT SUPPORTED HACK
Also tagged with one or more of these keywords: Create, linestyles
SoftPlan →
General Questions →
Have floor plans - need someone to create elevations and sectionsStarted by Jon Hodgkins , 27 Jun 2020 hire, create, elevations and 1 more... |
