Yes, had to edit wall join to zero and butt at these corners.
had to pull back 1/16 or the framing bled thru the opposing wall. I never had to "work around" this in 2018.
on a similar issue, and in the past I just lived with it, but is there a fix for an inside corner board to show on the main wall that the bump-out intersects?
the main wall is a continuous wall and I placed a blank arch opening in it to open up into the bump-out. I know you can build with 3 separate walls but sometimes that has problems as well.
also the corner board is not continuing to the soffit on the gable.
