In autocad, those who've used it are familiar with the trim between command, where you start the trim, but hit enter a second time
so that you can trim between two objects as opposed to having to pick the trim point or line.
Is there a way we can add that to softplan... when drawing details like the shutter pictured below... I currently have to break the line then trim past the top, and then trim past the bottom.... a single command to trim between lines would be great.
