Hello, I'm new at this and I'm trying to create a custom sheet set. I started with a blank 17" x11" sheet and a border about 3/8" inside.
How do I increase the thickness of the border line? I just can't figure it out. Help.
Thank you.
Posted 30 May 2019 - 01:27 PM
If you actually drew it with lines you can adjust the thickness in the edit menu while right clicking on the line. Then you can choose to have the center of the line filled solid in that menu and change the pen settings for the line (border) and the fill (center).
Another option is to go into your pen settings for the drawing or the system (drawing options or system options) and then set a pen to be extra thick there. Then, assign that border line in your drawing to that pen setting.
There are several ways to accomplish what you want, it just is a matter of how you are going to use that border and what you want for the look and ability to adjust.
Keep asking questions and people on the forum will have answers for you.
