windows
#1 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 11 June 2019 - 11:34 AM
i am doing a three season room with a eze-breeze window triple track windows that are 3' wide and 6'high is there a way to
put windows between 4x4 post with no  wall when i design it there are no walls just post i was trying to use jalousie windows
maybe there is a trick to do this,
Thanks Ron
#2 Jim Johnson
Jim Johnson
  • 289 posts
Posted 11 June 2019 - 02:32 PM
You could draw a wall plate and make it hidden.  Place your window on the wall plate and offset it as needed.
#3 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 11 June 2019 - 04:44 PM
thank you Jim i will try that
#4 Mark Petri
  • 1,510 posts
Posted 11 June 2019 - 05:27 PM
Any wall set not to extract and hidden ought to work, but the "plate" wall might work well especially if you need a trim or base for the windows. Just make that plate material something different than the framing material so you can control the texture if you make it visible in 3D. Don't forget to turn off headers too.
#5 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 12 June 2019 - 03:30 AM
thanks Mark
