Rowlocks...?
#1 Jon Davis
Jon Davis
  • 541 posts
Posted 14 June 2019 - 07:29 AM
What are ya'll doing to add rowlocks to brick water tables, if you're not using the the half brick/half siding wall type?
Case in point, I'm working on a garage that will be 10' Brick wall first level, and siding second level. I'd like for the
rowlock to show in the model at the top of the wall.
Don't really want to have to create a new wall type just to show it, In the past with brick column bases
I've just created a block using the solid feature and give it the appearance of brick w/ the surface feature. Bam. Brick Rowlock
around the top of my column base.
That's probably going to be the quickest/easiest route here as well, just curious what others are doing
in cases like this.
#2 Jim Johnson
Jim Johnson
  • 289 posts
Posted 14 June 2019 - 07:51 AM
Try using the banding command.
  • Jon Davis likes this
#3 Mark Beard
Mark Beard
  • 78 posts
Posted 17 June 2019 - 12:15 PM
Agree w/ Jim.  Play around with Banding and I think you can get more control.  I do this for rowlock/solider courses at my foundation walls a lot and at material transitions like you described.  Just depends on what you need, but being able to "trace" it on the walls/beams where you need it helps.
Mark Beard
LifeStage Home Designs
Office: 919.630.1224
Your future is in our plans
#4 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 17 June 2019 - 03:03 PM
Have you already tried adding a Frieze Board to the wall? Set it to be Inset and adjust the thickness so that it is just proud of the face of the brick at about 3.5".
