PDF to DXF/DXW
#1 Paige Jorgensen
Paige Jorgensen
  • 11 posts
  • LocationGrand Island, Nebraska
Posted 20 June 2019 - 07:04 AM
I am trying to convert PDF files to DXF to bring into Softplan.
I did some looking around on here to see what people used to covert and they recommended inkscape - however, it turns everything to lines, including the text and I have to take a lot of time to redo all the text in the plans, but I was just seeing if there is a way around this OR if there are any other programs or softwares that others use and recommend.
Thanks!
#2 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 20 June 2019 - 07:12 AM
I used to do this a lot when I used autocad.  All the products I found did as you mentioned turn text into lines.
The best I could figure out was to use and OCR the extract the text.  convert the drawing, erase the text.  Then import the text file and distribute the text where needed to be.  This was only worth the effort when there was lots of text as on a general note sheet.
#3 Paige Jorgensen
Paige Jorgensen
  • 11 posts
Posted 20 June 2019 - 07:23 AM
Dennis - what is OCR - and extract text through inkscape or what are you using to covert?
Posted 20 June 2019 - 10:17 AM
OCR = Optical Character Recognition
Posted 20 June 2019 - 10:18 AM
Paige ... What Softplan version are you using?
