Corners
8 replies to this topic
#1 Allen McDonnell
  • 953 posts
  • LocationIllinois
Posted 01 July 2019 - 01:01 PM
With this new patch im turning off "corners" and then all of a  sudden they are reappearing.  Does anyone else have this issue?
allen.
#2 Allen McDonnell
  • 953 posts
  • LocationIllinois
Posted 01 July 2019 - 01:04 PM
Im noticing if i make any change in a wall definition it reverts all corners back to default.
This needs to be resolved ASAP as i am always going into wall definition to make certain items visible so i can use the "adjust wall material" command.
#3 Allen McDonnell
  • 953 posts
  • LocationIllinois
Posted 01 July 2019 - 01:05 PM
I was not having this issue on the prior patch.
  • 5,092 posts
Posted 01 July 2019 - 04:56 PM
It's ALWAYS been that way. If you change a wall (don't know about just editing the definition), then the default corners have always been restored.
#5 Allen McDonnell
  • 953 posts
  • LocationIllinois
Posted 02 July 2019 - 07:01 AM
I remember the wall you were editing would add the corners back.  But now it is adding the corners back to wall definitions that i am not even touching.
I typically dont edit my walls but im doing a lot with profiles right now so i am updating them all the time.
#6 Jonathan Barto
Jonathan Barto
  • 131 posts
  • LocationPittsburgh, Pa
Posted 03 December 2019 - 07:40 AM
Another softplan issue with this version 2020.  This is the most buggiest version they ever came out with.   We are having same issue.
They need to make it simple.    Have a difference for inside and outside corners.  (where you can turn off inside corners by default)  I understand why they do the reset. when you add a new wall..  it is a huge pain to have to redo everything.  Especially when we have inside corners set to 0.
They do need to get this fixed asap.  It is very frustrating.
  • Allen McDonnell likes this
#7 Allen McDonnell
  • 953 posts
  • LocationIllinois
Posted 03 December 2019 - 08:20 PM
Are softplan employees monitoring the forum?
#8 Brad Graber
Brad Graber
  • 295 posts
Posted 16 December 2019 - 02:23 PM
This has always been an issue for me way back to my first version.... Version 12 I believe.  Once we turn a corner board on or off, it should stay that way.
#9 Brad Graber
Brad Graber
  • 295 posts
Posted 16 December 2019 - 02:36 PM
Here is a thred on the subject that I brought up some time ago.
http://softplan.com/...d-frustrations/
