I am having a problem that I really hope someone can help me with. Reinstalled SoftPlan on a new computer build and I am now getting an Error 712 message – That the time was set to an earlier time than the last time that I used SoftPlan. Of course, on Friday afternoon, SoftPlan is closed and I have a customer coming tomorrow afternoon to work on their home. Does anyone know how to correct this error?
Need Help
Posted 09 August 2019 - 05:56 PM
This is not the same error code but I have heard of this before.
The following is on the SoftPlan FAQ page ...
I am getting the following error when I start SoftPlan: Error 711: “The system clock on your computer has been incorrectly modified. To correct this problem, you must correct your system clock and contact SoftPlan Systems for a reset code.”
This error is typically caused by moving the key between two systems with different system clock settings when installing to the system with the earlier time. To correct, determine the time difference between the systems, remove the key and wait for the time difference or longer to pass before installing the key again. To avoid this in the future, ensure that the system clocks are matched prior to installing the key on multiple computers.
- John Jones likes this
Posted 10 August 2019 - 04:21 AM
Last night I completely erased SoftPlan from my computer. I went into the registry and removed every mention of SoftPlan. Reloaded SoftPlan and the program still would not fire up. Totally frustrated, I shut the computer down and even turned the ACP off so that the unit was completely dead. I finally went to bed about midnight. This morning when I woke up, I turned on the ACP and turned on the computer. After booting up, I tried restarting SoftPlan and low and behold, it came on.
Thank You Jesus!
I did not want to call my customer that has a meeting scheduled this afternoon and have to cancel because of a key that has an issue with a clock!
Rest assured that Monday morning I will be calling Tech Support and we will be discussing this issue. To be honest I am more than pissed off!!
No way should a program of this caliber shut you out because a key thinks the time is wrong. This has got to be corrected within the software / key or SoftPlan need to keep Tech Support open 24/7!!!
Did I mention that I am Pissed Off!!
