Gable pediment
8 replies to this topic
#1 Jonathan Barto
Jonathan Barto
  • 131 posts
  • LocationPittsburgh, Pa
Posted 15 August 2019 - 10:20 AM
Does anyone have a pediment in 3d that looks like this?   or is there anywhere I can get this??
Jon
#2 Rick Kingsbury
Rick Kingsbury
  • 170 posts
  • LocationSpearfish, SD
Posted 15 August 2019 - 10:44 AM
Check out this link. It may be helpful.
https://microsite.ca...rentTab=Product
Posted 15 August 2019 - 11:06 AM
If you download the 2D, you can create a simple 3D from it, and then reorient it in the symbol wizard.
#4 Jonathan Barto
Jonathan Barto
  • 131 posts
Posted 15 August 2019 - 11:36 AM
How would I do that with this symbol??   It is alot more complex than just a could angles..  it has curves and multi things going on...
#5 Jon Churchill
Jon Churchill
  • 421 posts
  • LocationThe Oaks, Australia
Posted 15 August 2019 - 05:34 PM
Jonathan, All this is possible in SoftPlan. Here is a quick example. Was done freehand so is not quiet symmetrical. Just use site mode to create the shape. I used sidewalk as the main shape and building outline to cut the shapes. You could initially bring in an image and resize to trace. Then just save it as a symbol and set the orientation to be correct. I am sure others on this forum can help with that.
By altering the height and width the pitch can be set to fit the roof line.
Jon
  • Jonathan Barto, Tom Rogers and David Zawadzki like this
#6 Martin Wrobel
Martin Wrobel
  • 82 posts
Posted 16 August 2019 - 06:06 AM
I never thought to use site plan mode to create these. I learn something new everyday reading this forum.
Martin Wrobel
Superior Home Design
Michigan
Softplan 2024
#7 Gary McKeon
  • 557 posts
Posted 16 August 2019 - 08:55 AM
Not sure I understand why to use site mode?
Posted 16 August 2019 - 03:06 PM
Because you can cut holes with site mode - otherwise you have to use the "in/out" method to get a FULL polygon, by making the holes part of the outer perimeter.
  • Gary McKeon and Allen McDonnell like this
#9 Jonathan Barto
Jonathan Barto
  • 131 posts
Posted 19 August 2019 - 08:11 AM
Jon
That is a really good Idea.
I will have to try that.  Never thought of doing that..
